Linen Cabinet
"Sometimes you have to look beyond the "what is" and see the "what can be"... The before and after simply speaks for itself  There were a MILLION little nail holes and exposed sunken screw heads in its construction...which all had to have 2 rounds of filling and sanding. Because this is knotty pine...2 full coats of primer before 2 coats of finish and sealer. General Finishes Linen and High Performance flat finish sealer. The botanical paper backing, addition of petite beaded trim and decorative wood accent at the base now elevate this to an elegant accent piece." - Raised Expectations
Raised Expectations
