A 50/50 blend of General Finishes Linen and General Finishes Holiday Red, then I wet blended with Linen applying both the mix and the linen with the same brush. The 50/50 blend was then placed in a water bottle with a 60/40 water to paint ratio, and I sprayed starting at the top of the dresser for some cool weathering and a drippy effect. General Finishes Driftwood was used for the top, I then sealed everything with with High Performance Topcoat in satin. The IOD Transfer was applied, then I used Miss Mustard Seed White wax, and a homemade gray wax using driftwood and clear wax (80/20 blend, wax to paint) to complete the look.
Morning Dew Creations
