Check out this awesome "Two Toned Geometric Chest of Drawers" from Brepurposed! The top and drawers were stained with GF's Java Gel Stain and sealed with our High Performance Top Coat. Here's Bre's trick to getting crisp clean lines. "I have to give a shout out to Reeves from The Weathered Door here because she is the pro when it comes to geometric patterns on drawers. I decided to try my hand at it using a tip that she shared on how to get straight lines. After staining and sealing my drawers, I taped off my pattern. Now here’s the magic trick: after your tape is down, use your poly or whatever protective coat you applied to your drawers (I used General Finishes High Performance Top Coat in Satin) and add another layer on top of the tape and the part of the drawer you’re going to paint. Now trust me when I say this works. I used to get so frustrated when I would pull my tape up and see jagged edges. Isn’t it the worst?! But now you know the solution."
