Front Doors Stunning Makeover with Exterior 450 Products
"Drove to St. Cloud, MN for these gorgeous double doors. They were 8 foot tall doors (11 feet including the frame), and weighed a hefty 300 lbs each. If you can believe it, there is absolutely no stain on the frame or doors in the before picture. The worn tan color comes from weathering and lack of maintenance. It took quite a bit of time to get these doors to its original African mahogany color.
"It took two layers of Klean-Strip, countless rounds of sanding, two coats of General Finishes water based Exterior 450 Olde Cherry Wood Stain, a thick coat of West System Epoxy and five coats of General Finishes Exterior 450 topcoat. The results are hard to believe... Although the drive was long, and the elbow grease was maxed out, these doors were well worth it!" - Fischer's Furniture Restoration
