Can't get enough of this entry way table from Team Sutton Designs! Team Sutton Designs says, "I used a base coat of General Finishes "Dark Chocolate," and sprayed two coats of "Antique White," then distressed to let the brown show through. The top was stained with a custom mix of "Kona" and "Dark Walnut." Everything was sealed with two coats of HPTC in semi-gloss."
