"The striking contrast between the white pearl and dark ebony make for a dramatic piece.
Once turned and sanded, I apply 2 coats of General Finish Wood Turners' Finish while on the lathe, and then knock down any raised grain. I then continue to build up the finish, using up to 10 coats, and polishing up to 12000 grit between coats." - Amanda of MercurePens.ca
This piece was entered into the 2016 GF Design Challenge Contest
MercurePens.ca
