Cocobolo Stair Treads
    General Finishes line of revolutionary water based flooring products provides easy to plan exits & runs as you can walk back over the stain in 10 minutes and are easily repairable on the job since the stains dry for recoating in 2-4 hours (humidity dependant). There are 19 intermixable base colors and our new pigmentation system offers superior UV stability & brilliant color. There are no strong solvent vapors, no combustion concerns and easy water clean-up   Learn more at : https://generalfinishes.com/water-based-wood-flooring-finishes/pro-floor...
NOVA Design and Build
Products Used
