"I filled the rather large voids with a mixture of epoxy and French Roast coffee grounds. The whole project was sanded to 600 grit before applying 3 coats of EnduroVar, while still on the lathe. I lightly sanded with 600 grit paper after each coat, and ended by using the 3 step Beall buffing system (tripoli, white diamond, and carnauba wax)."
Philip Wilson
