Curly Black Walnut and Amethyst Ballpoint Ben
The flashy figure in the piece of black walnut really pops with the high gloss of General Finishes Waterbased Turners' Finish. I first apply two coats of varnish and allow the grain to rise before sanding that down with the coarsest grit of MicroMesh. I then apply up to 10 coats of varnish until I'm happy with the coating. I then meticulously sand through all grits of MicroMesh to flatten and remove any specks, working up to a fine gloss. I apply one last coat of varnish before polishing with only the two finest MicroMesh grits. The result is an absolutely beautiful high gloss finish that is so durable!
Amanda Blacoe
