Dresser in a Custom Mixed Green Milk Paint Base and Java Gel Stained Top
Paisley Grace Customs created a custom mixed Milk Paint color for the base of this buffet using GF's Lime Green Milk Paint and Coastal Blue Milk Paint! Van Dyke Brown Glaze Effects was then applied on top of the green base, and GF's Java Gel Stain was applied to the top. Lastly, High Performance Top Coat was used to seal the piece for extra durability! NOTE: If you choose to use High Performance Top Coat over Java Gel Stain, make sure that you wait 72 hours between the two products since you are moving from an oil based product to a water based product. It is essential that the first is dry before applying the second.
